mfred68 avatar image
mfred68 asked
What does the Bulk light indicate in ess mode?
I've just started my new system in ess mode and I have the green mains light on static, the inverting light blinking, and the yellow bulk light on static, what does the bulk light mean? Also why foes the inverting light blink instead of being static?
ESSess discharging
Alexandra avatar image
Alexandra answered ·
@mfred68
Do you have a GX?
Usually the inverter light blinking means power assisting. Normal in an ESS system.
Bulk and mains on could be connected to mains, system in bulk charging. So you are not at target voltage yet for absorption.
mfred68 avatar image mfred68 commented ·
But while the bulk light is on, the batteries are not charging, and the grid meter is standing still.
Yes I do have a cerbo gx.
Alexandra avatar image Alexandra ♦ mfred68 commented ·
Being in bulk, doesn't mean it will charge, especially if you have the min SOC in case of grid failure lower than the percentage you are at. (There are a few other settings that affect whether it charges from grid.)
Bulk just is the battery state in your case at less then the rebulk offset voltage.
If you set it to keep batteries charged it will charge in bulk.
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
