Hi all,
I am finding an issue that my installer and I do not understand.
We have installed 2-phase system on a caravan.
Phase A is 4 x 180 watts Enerdrive Totaling to 720W which is connected to a Victron MPPT 150|85-Tr VE.can which produces about 55Amp when this phase is the only one running.
Phase B is also running the same 4 x 180 watts Enerdrive Totaling to 720W which is connected to a second Victron MPPT 150|85-Tr VE.can which produces about 55Amp when this phase is the only one running.
They are both connected to 3 x 300 AMPs Enerdrive Battery to charge them.
My Issue is then we have them both running they only produce 30 amps each!
But when running them individually they are running close to 55 amp each.
Why can't I get both Phases running at the same time and get the 55 each?
I have documented some more details on this setup on the following links.
https://workdrive.zohoexternal.com/external/writer/8d1899419560c1dd8beec8d59a2984974d8239a96455269a739385ed291837db
I have also attached some screenshots from the App.
Thank you so much for your help.
