cyon avatar image
cyon asked
Timer mode - use batteries with timer
Hello
I want to put in a request on Victron Cerbo.
Timer mode or something:
Timer mode set that you can say, I want to use batteries from say 22h00 until 09h00 in the morning and if batteries get to say 40% SOC, It must start using Grid/Generator and stay at 40% SOC until the PV can charge it back up to 100%.
like Sunsynk got this option.
This will help so much.
Thank you
Not sure - Admin please assign or create
Alexandra avatar image
Alexandra answered ·
@Cyon
This is achieved with node red and venus os large.
Possibly dynamic ess as well. Although i have not tried it that way.
The other way is conditional ac connect can be done with victron connect.
A further way, which has been a favourite is to use, if you cant really program, is the generator start stop on the gx wired to a relay on the inverter. The relay programmed to connect or disconnect the programmable relay based on conditions set on the GX.
cyon avatar image
cyon answered ·
I will need to learn node-red. I get so lost at the start.
It is pretty heavy going in the beginning.
There are plenty guys who have shared code with ideas.. A copy paste and tweaking works.
cyon avatar image
cyon answered ·
can Node-RED tell Cerbo only to charge the batteries with PV first and after the Batteries are full to do supply load/grid feed..?
You can do that with wind solar priority.
https://www.victronenergy.com/live/ve.bus:solar-and-wind-priority
diederik avatar image
diederik answered ·
I have a MultiPlus-II GX, I guess it works the same way as your Cerbo.
To charge the battery first with PV I use ESS and Optimized (without BatteryLife) modus.
For your other question charging at night, I'm using Node Red.
dangermouse avatar image
dangermouse answered ·
I use the relay out of the Cerbo to connect to the AUX of the multiplus. It gives a lot of functionality from VRM you can use quiet hours or periodic run.
You can set different SOC levels for quiet hours to normal.
