Translated to english ;-)
Hi hello,
A question: the-Ion setting in the app seems not to be corresponding whith the charging instructions I'm reading with my LifePO4 battery. I was wondering if somebody could help me with the ideal charging settings for my IP22/20A charger, in combination with my LifePO4 accu (200ah)
I have expert settings on. (sorry I'm dutch,So my app is in dutchs but it'll probably match the english language settings)
But euuhhhh What to add where?
Because in the manual of the battery manufacturer I read that the LifePO4 charging logic is rather different from lead acid battery.
In lead battery charging there's a bulk phase, absorbsion phase and a float phase.
But in LifePO4 there's I learned from the manual the charging phases are:
1. a constant current phase
2. a constant voltage phase.
And then charging with the following details:
So my question is; what to add where in the IP22 configuration so I get the charging logic recommended by the battery manufacturer?
Thanks a bunch!
Regards,
Ewout
