Hello there,
I have a Venus GX and the firmware version is 3.31. When I updated to this newest firmware version with large image without doing anything, I already got a warning which said GX is overloaded and real-time communication is disabled.
I finally succeeded to deployed one flow using enable(safe mode) Node Red. But any changes made, even just adding a debug node, is hard to deploy. It's so slow and always crashes with the error: failed to deploy or failed to contact the server.
I tried to start the Node Red directly with enable Node Red deploying the above verified flow. I then failed to open Node Red via Venus OS Large which shows the installation seemed to not have a running Node Red service.
My flow is not big thus I suppose it's maybe related to Venus's memory limitation? I am wondering is any way to run Node Red better in Venus GX? Any insights on this would be highly appreciated!
Thank you in advance!
