brezzi avatar image
brezzi asked
Switch Multiplus with Venus GX and NodeRed
multi.pngI have a switch connected to the I/O of my venus, now i would like to switch the multiplus 24/5000 on and off.
the I/O signal is working, it sends 3 or 4 to the multi. Sounds alright so far. But the strange thing is the multi is swiching on for maybe 3 sec and turns off. Same thing if i repeat pushing the switch.
thanks to help
MultiPlus Quattro Inverter ChargerVenus GX - VGXNode-RED
Sten avatar image
Sten answered ·
Is it a rocker switch or is it just a push button that release after a push.
That could explain the momentary on and then off
I'm not sure how your logic work, but I would do the logic with a simpel funktion node.
You need to do a litle Java script programming, but it is not that complicated.
