Im using a change over relay ( with diode) to bypass the split charging relay fitted as std.
I’m struggling to understand the H pin connection from the relay pin 87.
So several questions.
1.From the relay pin 87…is this the only connection required for the H pin?
2. Should this connection be fused (as per drawing)
3. What is the current draw? Voltage is i believe circa 7v
