I'll try to see if there is anyone here who knows about it.
I have an APsystems yc600 microinverter system and a victron multiplus 2 3000va with batteries. During a power outage, solar inverters continues to generate power depending on the state of the battery (frequency shifting).
I installed more solar inverters and now the output exceeds the Multiplus 2 maximum limit. Victron has a Factor 1:1 rule so increasing power beyond limit is not recommended.
So I have limited the yield of individual panels, but now I lose the maximum yield.
I would like some of the inverters to turn off immediately during a power outage. Can I do this adjustings solar inverter settings? There is setting named "Island open set"? Options are "no issued, open, close". Now the value is "open".
Will this be achieved by adjusting the settings or should some of the inverters be placed in different parts of the system?
