thomasw3 avatar image
thomasw3 asked
Cerbo gx must constantly be reset
My GX 50 display goes blank and the Cerbo-s GX stops responding disconnecting the power causes a reboot and the pair are up and running again. I saw several posts in the group with similar problems but no solution. Thinking that the USB may occasionally be drawing too much current I connected the USB to a source from the batteries. The problem persists. We are presently traveling in Labrador and Newfoundland so communications are poor and battery power is critical. Victron support has been a disappointment taking a week to respond and offering no troubleshooting or fix solutions. We will have WIFI for 2 more days so any suggestions would be appreciated.
cerbo gx
thomasw3 answered ·
I loaded the newest fw after the first time it happened. I can not connect with my phone after it happens until restart.
Paul B avatar image
Paul B answered ·
Try connecting using your phone via Bluetooth or WiFi and see if you can get a screen. Also make sure the cerbo is on the latest release fw.
Fideri avatar image
Fideri answered ·
@Thomasw3
I don't know your ecosystem but what if you disconnect the touch 50 and only use another device like your phone until you find a solution?
Not ideal but it could work in the interim.
F.
Fideri avatar image Fideri commented ·
Reading the messages again, I now realize my suggestion has already been tried.
F.
