Greetings to all you experts,
can I use a victron MPPT battery charger such as the BlueSolar or Smart Solar 75/10 to directly charge a battery taken from a power tool? These mainly come with a 18 V nominal voltage these days. I am not quite sure I have understood the information in the MPPT's documentation which seems to assume 12 or 24 V etc. battery voltages. Whereas I seem to be able to control the charging voltages through the settings, the data sheet seems to only allow load on/off settings - when the battery voltage is low - for 12 or 24V batteries.
Help is appreciated!
cheers,
Volker
