By 10 am in early April, usually, my SOC is 100% and batteries on float, with the sun on th pv's for another good 6-7 hours. At end of day the lowest yield readings are 3 kw, usually 4.5 kw.
Can I use this information to assess if I would have enough extra power, currently unused, to run a 1 kw pool pump and 2 kw inverter pool heater (the size I'd need) on such days while the sun is on the pv's?
