On board of my sailboat I use a Ruuvi sensor resulting in the capability to remote watch temperature and relative humidity by the use of VRM and the Venus software on an RPI. It works great
I installed a bilge pump with an automatic switch to pump out water in case of leakage. But the switch on the pump reacts only when there is a respectable water level (10 to 15 cm). I wonder if somebody already realized a connection with a more sensible leakage sensor, so I can watch if some small leakage has happened. And a kind of alarm should still be more perfect!
Maybe it is easier to use the GX tank 140 to make such feature possible???
Looking forward for some reactions
Bob
