I have the following system 3 pieces Multiplus 2 1 piece MTPP 450/100 Which settings must be selected on the ESS in order to feed the PV surplus into the grid when the battery is full. If I set the grid feed-in setpoint, the system feeds the selected amount into the grid. Only pure surplus feed-in doesn't work. Thank you for your suggestions
