I need some help please with assitants. I'm trying to configure a Multiplus II to turn AC2-OUT on manually during outages to run a borehole pump and other loads. What I need is:
AC2-OUT ON - When AC1-IN is present
AC2-OUT OFF - When AC1-IN is not present
AC2-OUT ON - When Relay 1 on in Cerbo GX (Must turn on AC2-OUT even when AC1-IN is not available / run from batteries and solar)
AC2-OUT OFF - When relay 1 off in Cerbo GX (Must only turn off AC2-OUT if AC1-IN in is not available)
The issue currently is that AC2-OUT is only on if relay 1 (CERBO GX) is energised AND AC1-IN is available, once relay 1 (cerbo gx) is opened AC2-OUT turns off. AC2-OUT also turns off after 10 seconds if AC1-IN is disconnected and relay 1 (cerbo gx) is energised. I was under the impression setting each assitant individually would create an OR instance? I had this working with SOC instead of relay 1 before ESS ASSITANT was turned on.
I currently have the assistants loaded in the following order. (I have tried many other arrangements without luck)
