Hello members,
I'm encountering an issue with my Victron system that involves the MultiPlus and Cerbo GX . Here's my setup: two Victron lithium batteries rated at 200Ah each, a MultiPlus 2 3000VA inverter/charger, a VeBus BMS 2, and a Cerbo GX for monitoring.
According to the user manual, it should be possible to switch between different modes and power off the MultiPlus when combined with a VeBus BMS 2. However, whenever I try to do so, the system indicates that this action is not possible.
I've made sure that the Cerbo GX is running the latest Beta version and have also tested with the official release, but the issue persists. Could this be due to misconfiguration on my part or something that requires adjustment? Could it also be related to a software update or compatibility issue between the MultiPlus and the VeBus BMS 2?
I would greatly appreciate any insights or advice on how to resolve this compatibility issue and ensure smooth operation of my Victron system.
Thank you in advance for your help!
Léon
