Hi - my setup is as follow:
- 1x Cerbo GX
- 1x MultiPlus-II 48/5000/70-48
- 2x Pylontech US2000C (connected as recommended)
- 1x 60A DC fuse between Multi and batteries
- configured as recommended (https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom)
I understand that one US2000C can provide 25A continuous charge and discharge and 100A peak for 1 minute.
DCL is set to 50A and CCL is set as well to 50A - I assume automatically by Pylontech BMS.
I noticed, some peeks going up to 40A for more than a minute (VRM portal).
Question 1 - is this now based on the fact that DCL and CCL is set to 50A?
Question 2 - If DCL and CCL is set to 50A, will this being real max or can it still happen that there will be a peak of upto 100A? Please keep in mind, my fuse is 60A and such a peek would kill my fuse ;-)
Thank you in advance
