airstreampictures avatar image
airstreampictures asked
Have battery mounting requirements changed?
I've been reading Victron's manuals prior to beginning my install, and I found this in the Lithium Smart Battery Manual:
"Mounting must meet the following requirements:
1. The battery can be mounted upright or on its side, but not with the battery terminals facing down. Note that this does not apply to the 12.8V/330Ah model, which can only be installed upright.
I've seen several posts here that state in definite terms that all Victron Batteries must be mounted upright. Has this directive changed? If it has, I have two questions: first, is it still a bad idea to mount a 200Ah battery in a position other than upright? (If so, why?) and second, can they be mounted on end? or just laying on the long side?
The whole idea of mounting a battery other than upright makes me a little nervous, but it would allow better weight distribution in my installation.
Lithium Batteryinstallation
Justin Cook avatar image
Justin Cook answered ·
First of all, good job reading the manual before install, that's a (unfortunately) somewhat rare occurrence!
But yes you're correct, the permissible battery mounting methods for all Smart Lithium batteries (except the 12/330) were updated in the manuals ehhh either late last year or early this year, I forget when exactly it was. So, indeed, a lot of slightly older admonishments of NOOOO it's absolutely forbiddennnnnn (more than a few of which were posted by me, LOL) are in fact no longer accurate.
Personally, having taken these batteries apart and seeing how they're supported and baffled inside, I would not myself mount them in any position other than upright unless it was a static installation like a house or garage; in a mobile installation I think that over a matter of years the odds of a mechanical failure inside due to vibration would be significantly higher when mounted on their side or on their ends than when mounted upright.
That's just my own assessment, though - at the end of the day, what's in the manual is indeed what's supported by Victron and if such a failure was to occur within the warranty period, you'd be covered!
airstreampictures answered ·
Thank you. That makes sense to me. And as I’m installing in an Airstream travel trailer, I think I’ll keep them upright.
Battery Compatibility
