newgen avatar image
newgen asked
Venus OS Docker: Data deleted after 1 Month?
i am using the default venus os docker containers on a raspberry pi and it works so far. Storage in the Pi is sufficient (20 gb unused).
However, I observe that the data gets deleted after 1 month. I checked the grafana.ini for the compactor or any deletion parameter but could not find any. The documentation states, that the data should be stored indifinitely. I checked with queries against the influx db, but there is definitely no data after one month.
Does anyone have an idea, where the configuration error is?
Venus OSdocker
kenzo avatar image
kenzo answered ·
I don’t know the actual implementation, but InfluxDB has a retention period configuration, see https://docs.influxdata.com/influxdb/v2/reference/internals/data-retention/ for details.
newgen avatar image
newgen answered ·
Hi. I finally checked your suggestions and it seems, it has to be set in DB, rather in config. When I go into the venus docker container with:
docker exec -it <containerid> /bin/bash
and run
influx
SHOW RETENTION POLICIES ON venus
It returns:
name          duration shardGroupDuration replicaN default
autogen       0s       168h0m0s           1        false
venus_default 720h0m0s 24h0m0s            1        true
That would match the 1 month deletion period.
I will try to increase it to a year and see what happens, using:
alter retention policy "venus_default" on "venus" duration 52w shard duration 24h replication 1 default
I am still not sure this will persist if the container is restarted.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
