sharpener avatar image
sharpener asked
MP II-GX manual is missing Appendix A
As per title, cannot find the connections picture any more. It does not matter whether I search on the Victron home page or use google, both bring up this link. Neither the pdf and html5 versions have Appendix A (though the non-GX manual does), why has it disappeared @Guy Stewart (Victron Community Manager)?
Trying to find out what to use for the negative side of the 12V supply available from the K1 output terminals as I want to power a small auxiliary board with 12V at a few milliamps. Am I right in assuming that the -ve side of Aux 1 is suitable for this purpose?
Multiplus-IImanual error
Duivert NL avatar image
Duivert NL answered ·
Here is appendix a:
sharpener answered ·
Thanks @duivert & @Alexandra. I wonder why it is in the MP II manual but not in the MP II-GX?
My GX certainly looks the same as the picture. But as upthread the text gives no clue about what to use for the -ve side of the 12V supply, any ideas?
Gx and non gx connections are the same
Yes you can use a aux - for 12v -ve
Have wired this up now.
Only get 11V from the 12V output using Aux 2 - as the -ve.
Also it seems to be floating with respect to earth/chassis which I wasn't expecting. Are these observations normal?
