andyp avatar image
andyp asked
vm-3p75ct on 100A Grid Supply when charging. Will it work?
Hi, I'm looking at changing my ET112 for a vm-3p75ct. It's an ESS setup with 2 MPIIs in parallel.
I have a 100A grid supply. Most of the time the batteries are supplying energy so the vm-3p75ct would be measuring near 0A. So all would be good.
However, I have a 4 hour cheap rate energy window at night and regularly pull near 100A. This is with 2 EV chargers, ESS battery charging, washing machine, tumble dryer and dish washer. The EV chargers have load limiting so they throttle back to not exceed 100A.
So will the vm-3p75ct just report 75A to the Cerbo but just work? It will only be charging at this time in Winter or charging with a low SoC limit in summer so it won't be trying to control the grid power in or out.
Energy Meter
ejrossouw avatar image
ejrossouw answered ·
@andyp No. Current rating aside the clamp will not fit over a 25mm2 incoming tail.
andyp avatar image
andyp answered ·
Thanks for the answer. That's a show stopper straight away!
andyp avatar image
andyp answered ·
In case it helps anyone else, I've just measured my 25mm2 tails and they are 11.1mm.
The CT is a Kemet C/CT-0810 which has an ID of 10mm.
