jackk avatar image
jackk asked
Max wattage output when Multiplus II 12/300/120 is in Passthrough mode
I have the multiplus II 12/3000/120 in my 22 sprinter van. I am not a highly technical person and am confused by research I have done on this topic. I know when I am using the inverter thru my 600ah of Battleborn batteries I am generally limited to 2400 watts at one time. But when i am plugged into 120v 20 amp shore power and multiplus automatically switches into pass trough mode (from my house) am I still limited to 2400 watts max in the van or can i exceed that?
Thanks
Multiplus-II
delf67 avatar image
delf67 answered ·
You can use 20 x 120 (A x V) = 2400W from pass thru + 2400W from inverter with power assist, so 4800W. As long as the cabling etc is correctly rated.
