Dear colleagues, I have a problem with the correct setting of the GX communicator incorporated / embeded in the Multiplus II GX. When the LAN is not available or WIFI, GX stored data probably but it does not export the data stored in the memory to the VRM portal when connection is again established . You do not know which type ( nanopi, beaglebone,cerbosgx or ccgx) and which semi-sed version of firmware is reliable and realy right ?
