I have a Fogstar lithium battery, when I charge it via mains with the IP22 when it is full it goes onto storage mode (the smartsolar follows suit). While still on mains power the battery level depletes but the charger doesn’t change, stays in storage and doesn’t charge the battery. If I unplug it from the mains charger for a few minutes and plug it back in, it changes to bulk and charges the battery again.
Is there a way to turn off storage mode as it isn’t required for lithium batteries?
The victron chargers are set to the lithium presets.
Thank you
