Good Morning
We have 2 multiplus 2/3000/120 in parallel with 800Ah of lithium batteries and solar.
The system is on our RV which we live and travel. We moved yesterday (only about an hour) everything was working fine when we left. When I hooked back to the power our system will not charge the battery bank and says that the AC is disconnected (no pass through).
We have been running on battery power/ inverter since which, BTW, works great.
I have made sure that the firmware is up to date and checked all my settings including turning off the virtual switch. There are no error codes and the grid settings are good. Nothing seems to work. When I turn on the AC power at the breaker the system clicks back and forth as if it wants to switch over but something is holding it back that I cannot seem to find.
Anyone else have a similar issue or advice?
