Hi i'm planning a three-phase installation (3xMultiplus-ll 5000) with Pylontech batterie at home. How ist it possible to use the solar combine with grid for heavy equipement like e-car or heat pump and use the batterie only for home usage.
The AC output 1 is for the Home usage witch backup or use from Solar energy at night, right ? No havy load of course.
The AC output 2 ist for thoses havy load, it has no backup fonction and work on AC in = grid. But did it also use prior the energy from solar vor the AC in ?
Thanks
