I finally have my system up and running:
- Multiplus II 5000/70/50
- SmartSolar RS 450/100
- DIY LFP battery with JK BMS
- Cerbo GX
For now, I have programmed via a couple of assistants turning AC Out 2 on and off so it can heat my how water via the immersion heater.
Currently, it's something like:
- turn AC Out 2 ON when SOC > 90%
- turn AC Out 2 OFF when SOC < 85%
This appears to work fine.
However, the only way I can modify this is by using either VE Config remotely or taking the cover off the MP to connect with my Mk3 USB adaptor.
In both cases, this requires a restart of the MP2 which isn't ideal.
Is there any way to control this remotely that doesn't require the convoluted editing of VSC files and VEConfig?
I haven't looked at using third party software like node red or home assistant. I'm using just the built-in feature set of the Victron ecosystem with a basic ESS setup and a further two assistants for the AC Out 2 control.
