How does it work?
On the smart bms 12-200 manual, the system examples show a standard alternator (no special regulator mentionned) connected to the starter battery (lead acid) and (in parallel) to the “alternator port” of the smart bms.
As mentioned elsewhere the smart bms as no charging profile nor tension elevator, so my question is:
The standard alternator regulator should give between 13.5V and 14.5V which is OK for the starter battery, but how it is possible to charge also the lithium battery with a steady 14.2V during absorption and 13.5V for floating?
How the standard regulator is supposed to respond to lead-acid battery AND LFP at the same time?
Should we use some sort of advanced regulator (ws500,..) or insert a DC/DC charger between the starter battery and the alternator port of the BMS?
