Hi Guys,
I'm learning about solar and while trying to figure out how to size the MMPT that I will need to support the 2 strings (13 x 545 W panels each string) I would like to install, I was wondering if Chat GPT or the New Google Gemini AI were able to calculate it properly, it is just an experiment and both AIs seems to be able to calculate everything and offer a recommendation.
Unfortunately I'm not able to judge if they really know what they are talking about or just "pretending to know" and offering an advice based on their ignorance! :D
If anyone experienced is interest (Just for Fun) in taking a look at the answer (attached as image) would be cool to check if they answered correctly or if the are just Artificial Rubbish! :D
The prompt I entered was:
"What victron MPPT is needed to support 2 solar panels strings put in parallel, where each string is comprised of 13 solar panels connected in series and each solar panel STC Characteristics are: a 545 Maximum Power, a 47.0 Open Circuit Voltage, a 14.86 Short Circuit Current, a 39.0 Maximum Power Voltage, a 13.97 Maximum Power Current and a 20.9 Module Efficiency?"
That info correspond to the TW Solar TH545 Panels
And the AI answer is on the attached image.
I will presume the answer is wrong but I cant really tell.
Note: I know there is a solid MPPT Calculator and tone of info to properly design the system and I'm planning to use it of course, I'm not that lazy to expect that an AI will do all the analysis for me, but I just thought how cool it could be if you can provide info about your today's house energy consumption, your expectations (on-grid/off-grid, expected savings, locations, a blueprint of your house, etc.) and get in return a properly sized PV System with the required Bill of Materials, diagrams, etc no?
I have no doubt we will see something like this rather sooner that latter, even Victron itself could be already thinking in something similar.... or not! :)
Cheers,
PP
