We have installed 2 x Quattro 15kVA units in parallel on a grid tied site with 2 x 15.4kWh BYD batteries and 2 x fronius 6 primos.
All is well with the system except when it begins charging the batteries from the grid.
A loud oscillating humming noise comes from the Quattros and the amps start to fluctuate with the noise. The amps recorded on a DC clamp meter jump from 90Amps to 125Amps, then back down, then back up.
This happens when charging from the grid only. When the grid is feeding straight through it is fine. When the batteries are discharging, also fine.
Any ideas as to what is causing this problem or any other similar examples anywhere?
Quite urgent to resolve this before Christmas as there are usually power cuts in the area where the system is installed.
https://www.youtube.com/shorts/4FViEa14HNo
