Hi There,
I've got a new off grid setup that utilises 3 x redflow batteries and approx 10kw of solar, running a Cerbo GX, MPPT 450/200, Multiplus inverter, with an EVCS NS. The batteries are wired on the DC bus.
I've been struggling to get the EV station to work in auto mode. For a while I couldn't get it to choose auto, I finally managed to get that setup, but now I can-not charge my car regardless.
I set the minimum SOC as 40% to try and get it to work, but even in manual mode, with more than 40% charge, it says the SOC is too low. This seems to be regardless of having solar or not.
When I look through the manual, I believe there is an option to say it off grid, however I cannot see that anywhere?
Any suggestions?
