Greetings Victron community,
I have a question related to the previous discussion here, but I'd like to separate it and make it a more generic Cerbo GX-related question.
What should end-users expect when it comes to the communication of different devices directly with each other when connected to different ports of the Cerbo GX?
For instance, I am currently observing the REC-ABMS connected to the BMS-Can port of Cerbo GX successfully communicating with devices on VE.Direct and VE.Bus ports. My question is, should I expect the same connectivity (switch-like network functionality) between the BMS-Can and VE.Can ports of Cerbo GX?
I appreciate any insights and experiences the community can share regarding the intercommunication capabilities of different ports on the Cerbo GX.
Thank you.
