Hi, I'm new here and really could do with some help.
So I have the Cerbo-s GX and touch 50, I want to use the relay 1 to switch on the water tank pump. It's all connected but when I press the pump button nothind happens to the relay, there is power between the NC and common but nothing bwtween NO and common, it doesn't switch over. any ideas?
Thanks in advance.
