After installation with the switch in CHR position, the charger does not start after connection to the shorepowergrid. All leds were off. After disconnecting shorepower, and the switch to ON the inverter started. After this the charger also worked. However, the problem is now back: charging is okay but inverter refufes to start. All LEDs off and plenty battery power. Is this a product failure or installation issue ?
