Good morning,
in a previously post I had a problem wurh the MultiPlus-II2 4/5000 while in "On" mode and connecting a 2500W Generator, which generally works fine (support 2200W without any problems) but it has problems stabilizing the frequency abd oscillate 50-56Hz.
I have just rewired my MultiPlus-II 24/5000 and a spare Phoenix 24/375 that the circulation pumps of my heating system can continue.
Then I switched the MultiPlus-II 24/5000 into "Charger" mode, but it does not accept this creepy AC input. Not even if i set "week AC input".
Any ideas?
Currently I use a LEAB ABC2430 and an Invacare 24/8 charger in parallel, but this is only a temporary solution. I consider to buy a Skylla-TG 24/100 set it to 30,6V with Voltage sense and simply regulate the charging current accordenly to the used Generator, but currently I do not have the financial power to buy a 2000€ charger...
