is it possible to manually select the power source from which the EVCS should take the energy?
In winter my pv doesn't produce enough power in order to charge my car. I was told that is not good for the battery when it is discharged "very" fast and as the wallbox can charge with 22kwh it would be better to take the energy from the grid and not from the battery as sooner or later my battery will get empty.
Any ideas?
