timspower avatar image
timspower asked
When shore AC connected are watts limited to multiplus size
Hi I'm pondering downsizing my multiplus from 2000 watt to 800 watt, but occasionally will want to run a couple of things slightly higher power than that. If I am connected to shore power would the multiplus still have the 800watt limit or does the AC literally pass straight through and allow me to use eg. A 200watt power tool? Many thanks
Multiplus-II
nickdb avatar image
nickdb answered ·
It passes through to the rating of the transfer switch, which appears to be 16A for that range.
timspower answered ·
Ok great thank you, that's what I was hoping was the case
