mikekulls avatar image
mikekulls asked
Multiplus2/Quattro, grid connect not possible but what is possible?
I see the MultiPlus II and Quattro are not approved for grid connect in Australia but what is possible? Could I run some items in my house from a MultiPlus, have it charge from its own set of solar panels through a victon MPPT? I presume that is legal as it's a completely disconnected from the grid. Is it then legal to charge it from the grid? Then, is it legal if I run a separate set of powerpoint throughout the house that are connected to the multiplus? Also legal to rewire all the light circuits to it? Quick pic below of what I was thinking. Will be fused/isolators as appropriate
Thanks
Multiplus-II
chrichri avatar image
chrichri answered ·
Why should that be a problem? As long as you do not feed any energy back to grid (this you can set so) there is no big deal
mikekulls answered ·
I'm not sure because I don't know the regulations. I came across a post saying it had been approval for generator input, which seemed to indicate you can't even draw power from the grid.
