antl avatar image
antl asked
Smartsolar MPPT 75/10 No LEDS
Got up this morning to find my Smartsolar MPPT 75/10 appears to be dead?
It has no LEDs on, but I can see the unit in the Victron App. However, when trying to connect to the unit it fails. There is 12.76v at the battery input terminals of the charger.
Disconnected and reconnected the unit, still no LEDs.
I assume the unit has failed?
Thanks
Tony
MPPT SmartSolar
@Antl Have you checked the fuse in the bottom of the mppt??
Mike Dorsett avatar image
Mike Dorsett answered ·
If there are no led.s and you cannt get a connection to VE connect, then yes, the unit is probably dead. Try checking the on board fuse .
