Hi
If I install a Victron 8KVA inverter with 5kwh BSL battery with the idea to install an additional 5kwh battery in the future, is there a way to limit the inverter output to 5kw to prevent the battery from overloading/tripping because it can only deliver 5kw?
Thank you
