craigrob11 avatar image
craigrob11 asked
RPI Screen blanking Recommendations for Venus OS/support
@Kevin Windrem
Looking for some advice trying to set up a 5” touch screen I have successfully managed to install RpiDisplaySetup And also calibrate touchscreen unfortunately, I am unable to dim screen it runs permanently on I have read on https://github.com/kwindrem/RpiDisplaySetup only the RPI touchscreen supports dimming I am currently trying to use a Waveshare 5 HDMI LCD (H) I am unsure if this is a supported touchscreen or if I have set up the RpiDisplaySetup incorrectly
if this isn’t supported, could someone push me in the right direction Don’t particularly want a screen with pi connected to back due to space and screen location
cerbo gxVenus OSRaspberry Pitouchscreendisplay
5 comments
badfrogg avatar image
badfrogg answered ·
Thanks for that video link.
So /sys/class/graphics/fb1/blank worked for the 5" waveshare display connected to the ribbon cable, is that correct?
badfrogg answered ·
Oh, my man! I did it!
I didn't understand that to run the setup script you needed to specify the whole path:
/data/RpiDisplaySetup/setup
And then I was getting hung up on the "Available actions:" menu. It says (i) to install and I was thinking that I already installed so that was not the option to pick.
badfrogg answered ·
One odd behavior to report.
After running: /data/RpiDisplaySetup/setup , I loose the CAN Hat (VeCanSetup).
I have to reinstall it every time.
