Prince Mthembu avatar image
Prince Mthembu asked
Multiplies 2 48/10000 Humming noise
This Unit came into my RMA centre with an unusual sound when Mains power is introduced to charge the battery and run th
e loads.
I then replaced its Mains plus Control PCBA with a new one and tested the unit, it seemed fine.
Now the client just sent me a Clip of the inverter with mains power on and the system is making a humming sound . This time a bit loud.
Is this normal?
Multiplus-II
Rob Duthie avatar image
Rob Duthie answered ·
Hi
Depending on what loads there are on the cicrcuits it can hum, as this is a low frequency inverter with a very large transformer it will hum from time to time.
Regards
Rob D
NZ
