I'm running 6x Pylontech US5000 in parallel, linked via the CANbus to a CerboGX. Charging this I have 8 BlueSolar MPPT 150/35.
My MPPT are a mix of hardware rev2 and rev 3, rev 2 are running FW 1.61 and rev3 are running rev 1.59. Cerbo GX is F/W 2.91
The problem I have is that the FW1.61 MPPT units report battery overvoltage as soon as any charging starts - even if I replace the solar panels with a bench PSUand gradually increase the PV voltage. The only way to recover seems to be to disconnect VE.direct, PV and battery connections and restart it.
I can't seem to find a way to regress the F/W to 1.59, so I'm not sure what to check next Any ideas!
Thanks
Kevin
