Running Venus OS 3.01 and are having issues with a Shelly Pro 3EM configured as AC Load. It works for a while (couple of hours) and then stops updating/reporting. Same error happened on Venus OS 3.0. Added the Shelly device after upgrading to Venus OS 3.0 and it was super easy.
If I change the type from AC Load to grid/PV Inverter it starts reporting (as new device) and then I clear old device & change back to AC Load and delete old device it continues to work for a couple of hours as AC Load. When ut stops updating the values are still there, they just dont update. So its not that its blank or something similar.
Since I don't do anything on the shelly it seems that it works all the time, but the Cerbo stops processing the received data.
Is this a Known error and if so is there a work-around?
Also, the device doesn't show up in the device list in VRM nor in the dashboard in VRM. The unit has ID 41 locally but isn't shown in the local GUI either apart from the Device List.
/Kaj
