pamapama avatar image
pamapama asked
Connect two GX devices to one battery via
Can I connect two GX devices to one battery using a RJ45 splitter?
cerbo gxBMSVE.Can
nickdb avatar image
nickdb answered ·
Might be better off just daisy chaining them. No idea what other issues that may cause with two on the same bus.
pamapama answered ·
Could you explain what you mean by daisy chain them?
CAN is a single bus that you attach multiple endpoints to.
So, depending what model GX you have, you would have a terminator on the battery side, connect the BMS to the first BMS CAN port on cerbo1, then connect the second BMS CAN port to BMS CAN port 1 on Cerbo 2 and a terminator in the remaining port.
In theory that should work, but never tried it myself, nor could I say what the effect of two GX's on the same bus might be.
pamapama answered ·
Yes daisy chaining the GX devices BMS Can port is like using a splitter cable. I am concerned about the software side - will it work?
