I have set up a MultiPlus II in ESS mode with an external current clamp, a Cerbo GX and SoK batteries connected to the Cerbo. There is a 3rd party solar inverter on the AC line, and I use an OpenEnergyMonitor to record power usage.
It was working fine for a couple of weeks, but would never discharge the battery bank below about 50%, as the voltages in the assistant were set too high.
Today I adjusted the voltages in the ESS assistant down to 46.1V and uploaded these to the MP2. Now the system keeps charging for short bursts even when the battery is above the Minimum SoC set-point (25%). Any ideas what's wrong?
Thanks for any help,
Present minimum SoC from Cerbo:
Short bursts of charging the battery at full power as shown on the Cerbo:
Short bursts of charging as shown on house energy monitor
