Hello, I would like your opinion... I have several large capacity lithium batteries and have the Blue Sea 7700 remote battery switch attached to each. I want the 7700 to connect or disconnect each individual battery. There is a remote switch that can be attached to the 7700 allowing it to be switched on or off from a remote location. I thought it would be good to have the yellow lever on top of the 7700 accessible by hand for maintenance, checking the batteries individually or even in an emergency (to disconnect the batteries quickly).
With the remote switch wired to the 7700, physical access to the yellow lever might not be necessary?
I look forward to any input/opinion on this.
Thank you, Jeff
