In an ESS system, is there an explanation in the algorithms that justifies that when charging the battery from the solar panels, it takes more energy from the electrical network when we are in a parallel model than when it is just an inverter? as well as 10 times more, is this normal? or it may be a consequence of a bad configuration, a firmware update. ( configured with optimization with batterylife )
