I would like to activate "Disable Feed In" using NodeRED. A few seconds after DFI is set to "1", it will return to "0" by itself. It's the same with "Switch Position", about a minute after setting "2 Inverter only", it will automatically return to "3 On".
ESS mode is 2. Is it nacessary mode 3?
I would like to turn off Feed In automaticaly for nights.
Thanks.
