I have two questions that I'm hoping y'all can help me out with. First some background. I also attached a diagram.
I have two 6v batteries in series for my travel trailer 12 volt system. I installed a marine kill switch on the NEG side for storage when the trailer isn't in use (vampires on board eg CO monitor, etc.). I was initially going to install the shunt on the ground side of the cutoff (Fig. 1) so that the 712 monitor wouldn't draw current, but in looking through the forums, it sounds like I would lose history and synchronization on the 712 monitor.
Question 1: Is it better to install as Fig. 2. with the shunt directly off the battery, or can it go after the cutoff switch as in Fig.1?
Question 2: How much will the monitor draw if it's not included in the cutoff, as in Fig 2?
Thanks in advance for the help
