My MultiPlus 24/5000/120 23V keeps shutting off and cycling back on. Poking around with a multimeter, I see that shore power cable is providing 218V, yet the Multi is showing 205V. When I apply a large load (like aircon or water heater) the voltage drops low enough that the Victron rejects based on low voltage. Systems cycles off/resets, then repeats once the load is applied again. Under light load, the system works fine. This is not a new install, it's been working fine for 4 years with these loads, so this is a new development.
So the question is - why the 13v discrepancy between shore voltage and what the Victron seems to see/report via the app and VRM? I'm assuming this is my issue?
